Persistent LED Issues
NozzyD
Hello everyone…
So recently I bought some Fuzz Face boards, the Sun Flower & whatever they call the NPN Si version?
Anyways, I’ve put a couple of them together. They seem to be working fine, & they sound really good but I just keep burning up LED’s?
In both cases the LED would work for a couple minutes, then it’ll start to strobe &
oscillate. This “strobing” makes an audible thump in the signal, & eventually the LED burns up…
If anyone has had a similar situation & solved it, I’d very much appreciate knowing what you did to address this problem!!!
Thanks!!!
Hello everyone…
Thanks!!!
Did you use the standard LED 4k7 resistor in your Build - Yellow, Purple, Black , Brown, Brown
