Phat-O-Caster mod: re-voicing Strat bridge pickup for a passive boost
MichaelW
Some of you may recall a few months back I converted my "Goldie" Strat into an H-S-S configuration since the bridge position was already routed for it.
At the time it seemed like a good idea to have at least one of my Strats with a beefier bridge sound.
And it was exactly what I expected it to be and I loved it......for a minute.......:p.
Tonally it did exactly what I wanted at the time, but I found myself not playing it much. I tend to pickup one of my hum bucker guitars when I want that sound and somehow the "modern" Strat config just didn't suit me as much as I thought it would. So that guitar didn't get a lot of love.
Fast forward a bit and I came across a really interesting mod from Waylon McPherson Guitars. He's got a Youtube channel with a lot of neat guitar, pedal and amp mods. Check out his channel.
I'm not really into trick wiring or fancy mods on my guitars but this one caught my attention because its totally passive and it's a pretty significant new sound, yet all the stock Strat sounds and positions are all still there. Unlike my H-S-S which is both a compromise and a commitment to that compromise (for me that is) because I really missed the stock Strat sounds, even the single coil bridge pickup.
This mod give you the option of easily increasing the output of your bridge pickup 50-70% and adding a significant bass boost (depending on how you select the mod values) yet with a click of a push pull pot restoring your stock Strat wiring and tones.
In a nutshell there are two parts to the mod:
1) Using a push pull or toggle (SPST) you're reconfiguring the #1 switch position (or bridge pickup) into Middle+Bridge but wired in series instead of parallel. That alone is a cool mod in and of itself as it gives you a nice passive boost in output and mids, yet it does not sound like a hum bucker, it still sounds single coil-ey , just beefed up.
2) The second part of the mod is "re-voicing" the middle pickup. Essentially shifting its resonant peak towards the bass register by wiring a capacitor in series between the bridge and middle pickups. How much you shift it bass wards depends on the value of the cap.
And I also found out that the value of the cap needed also depends on how the pickup is voiced to begin with. Now the re-voiced middle pickup is combined to the bridge pickup in series and you wind up with fuller, beefier, stronger sounding bridge position, yet it still sounds like a Strat pickup.
In the video of the mod, he started with a 220nf cap to somewhat exaggerate the effect. So I figured I'd start with 220nf and work my way down from there. Well, when I first tested the mod I thought I had done something wrong. Anything from 220n to about 120n all I got was "mud".
Turns out that for my particular middle pickup, which is vintage overwound (~6.8k) anything above 100nf shifted the resonant peak right off the chart. It took me a while of troubleshooting before I figured out that I needed to be testing a much lower range of capacitors.
My finalists from my workbench ranged from 68n down to 15n. I wired the mod with test leads coming out from under the pick guard so I could play test the results with headphones. I landed at 39nf for this set of pickups. It's a pretty sweet mod.
When the mod is engaged only Positions 1 & 5 are usable. (Neck and Bridge) But it's pretty cool (and useful) to switch between neck and bridge positions but have a beefy, volume leveled lead tone.
I imagine the usable range of capacitors might be different on a different pickup wind. So if you try this mod, try everything from 220n down to 10n. Somewhere in there is the sweet spot.
I'm not a fan of push pull pots but I'm less of a fan of extraneous toggle switches. So I opted for the lesser of two evils and used a CTS Push pull pot I had on hand. It was a 500k pot but I soldered a parallel resistor to bring it down to 250k. Yes, that messes with the taper adversely but it's on the middle tone pot which I literally never touch. I wire my Strats with a dedicated tone pot for the bridge position and that's the only one I fiddle with. Still these CTS Push Pulls are MASSIVE. After using them in a few guitars, I've come to the conclusion that I'm not a fan of these pots either. The little PCB is really not helpful because you have to map them to the switch lugs and they're not very convenient to solder. If I were to do this mod on another guitar I'd opt for plain old push pull with the DPDT lugs.
My little test rig so I could audition the cap values outside the guitar.
Initial round of finalists....I also tried some different kind of caps. PIO, Orange Drop, Mallory, Tropical Fish. To my ears the Mallory and Orange drops sounded the best. But I didn't have one in the final value I chose so I just used a film cap.
After whittling down the finalists on my bench amp, I finalized the choice in my studio with headphones.
I wound up just soldering it to the lug tits instead of f'ing with the stoooopid PCB pads. For the tone cap there wasn't much room to squeeze in one of my fairly large fave PIO tone caps, so I used a 200v Orange Drop (0.015mfd)
Here's a couple of screen grabs from Waylons channel of the mod.
I'd highly recommend watching his video of the mod if your interested.
And here's my demo of my testing the finalists. You may need to use headphones to really get the full effect.
Hope this is useful to someone out there. I'm pretty tickled by this mod. (How long I remain tickled remains to be seen......:p
That's a really simple and great sounding mod! Man, thanks for sharing! Definitely gonna try out some caps on my HSS Strat
Interesting mod that I’ve never heard of. I did come across the Don Torres “mid boost and mid scoop mod” which uses and inducter written by Dirk Whaker but I have not tried it. I just happened across it on premier guitar.
I’ve actually been in the process of converting one of my SSS stats to an SSH seeing as I only have 1 guitar that isn’t a Strat from almost 30 years of playing lol. What pups did you use for your SSH? I thought about getting some hotter noiseless to go alone with some humbucker but I haven’t tried any. Alone single sized humbucker I’ve tried was way back in the day I had 2 lace sensor gold and a Duncan hotrail in the bridge with a TBX tone control for the bridge. I actually really liked that set up for what it was. It was on an old E4 American series and was my these really guitar. Don’t think I realized the center indent and its purpose until I had the Duncan installed.
What you plan to do with the discarded humbuggie?
Man, I did a lot of Dan Torre's mods on my guitar back in the olden days before the interwebz and he sent out a little paper catalog hahah.
I did the mid-scoop but not the boost. Dan Torres also did modded my amp. I had a Peavy Bravo tube amp, it had a ton of gain but was kinda harsh. His mod's made it much more Marshally.
Funny you should ask about the pickups, I just did Ver 2.0 of my Phat-O-Caster. I use a Push-Push pot instead of the push-pull. I like it a LOT better. I absolutely detest push-pulls and avoid using them except when there's no other choice. I was actually thinking about getting a Fender S1 switch for the Phat-O-Caster but they're kinda pricey, between the pot itself and the special knobs.
But Ver 2.0 has some ToneHatch "Vintage Class" A5 pickups for the neck and middle (5.95k) and a Guitar Madness A5 Alnico bridge (7.5k).
The hum bucker I used in my H-S-S was also a Guitar Madness A5 PAF style. Inexpensive ($20) but great sounding pickup. I have a set of them in my H-H Tele as well.
Nothing is ever "discarded" but it's sitting my spare pickups box for now. You want it? DM if you do. It's a Double Cream coil, but I've got some raw steel covers I could throw one on if you want.
@MichaelW PM sent. I prefer to barter lol. How are you lining the tonehatch A5? I’ve had their “hippie stew” on my list for the longest. Some for 5/2’s or even tru some A2 or A3. I don’t venture much lol.
I've only tried their Vintage Class pickups but I sent some out in the BBOP last year and @Guardians of the analog is using the Texas Spirit set I think and he likes them. But I like the BootStrap pickups more (well, I have more experience with them). Plus they're cheaper.
Great write-up on the mod, Michael. The cap part is also known as the De-mud Mod and was used on 4 conductor humbucker in the neck of a Les Paul. Most folks used a handy .047 from a strat or a .022 uF cap from the existing stock circuit, but could not use the neck tone pot after that. Most folks did not care.
Great write-up on the mod, Michael. The cap part is also known as the De-mud Mod and was used on 4 conductor humbucker in the neck of a Les Paul. Most folks used a handy .047 from a strat or a .022 uF cap from the existing stock circuit, but could not use the neck tone pot after that. Most folks did the care.
Interesting, I saw that video but didn't watch it yet, I'm going to have to take a look at that. I'm usually always struggling with getting enough clarity on a neck hum bucker without going too low in the winds. I may have to try that!
This is a really cool mod! Almost two decades ago I tried a Clapton Strat that had an all series mod: when engaged all three pickups would be wired in series. I remember really liking that sound. This mod reminds of that for obvious reasons.
Now, where’s my Strat… 😉
The first Fender I ever owned was a brand new Fender "The Strat" in candy apple red. It had an extreme narrow U shaped neck, weighed a ton and had a finish which started to discolour almost immediately. But it did have some cool switching. The third knob was a two-way switch and one of the settings was the bridge and middle pickups in series to act like a humbucker. It worked quite well I remember - although whether I would be so impressed these days I'm not so sure!
I reckon one of those two-way pot-style switches could be a good way to implement this mod. If you don't ever use the middle pot anyway... You could get one with more that two settings to try different value caps maybe.
A while ago I changed the tone pot on the neck pickup of my Les Paul into a bass-cut rather than treble-cut. It has made the neck pickup so much more useful. That's a mod I really recommend for boomy neck pickups. I just have to roll back the tone knob to around 8 and the balance between the pickups is perfect.
Bass roll off is the most useful control on modern guitars. I have it on 3 out of 5 of mine.
G+L have been doing it for years, but I'd be less likely to use a bass roll-off on a Strat style guitar than say a Les Paul. I guess it could be cool if you played funk.
I think bass controls are vastly underrated.
Yeah I have an S500 with treble and bass control. Still useful sometimes but much more useful on my Reverend with revtron pickups and my Novo with P90s.
Care to share cap’n’pot values with P90s? I have TB+V controls currently on my baritone with only one P90, but thinking about rewiring it, because currently treble cut isn’t effective practically and bass cut just cuts too deep. Gonna add humbucker to it too, but into middle position as I don’t like neck pickup with low tuning.
I gotta look at the specs. Or open it up which may take me a while…
