Newly joined. Am not an electronics whiz. Last thing I ever built from scratch was a Heathkit car radio.
Need some insight to a problem with an old 7-100 made in the early 70's.
When I plug into the jack, get this loud low frequency motorboating. No guitar comes through.
Prior to experiencing the motorboating:
After years of not using the amp, I decided to clean it up. Took off the metal circuit board cover. Noticed the blue wire with the resistor attached to the pre-out jack had come detached.
Using this photo I resoldered it to the "+" terminal on the board. Is this right? AFIK the board below is of the germanium trasnsistor '70's model. T'was all I could find.
I should've tried the amp before I took it apart. Nothing seems detached now.
I also tried to pull off the metal cover that houses the input jack and volume/switch knob. Couldn't get the cover off after taking off the four screws but did loosen the nuts thinking the cover would come off. No go. So I just put back the nuts on the jack and pot. Tried not to make the jack and the pot spin from its position as I tightened the nuts.
Lastly I reflowed some of the solder joints on the board. Nothing is touching.
Thick board and with enough space between the traces. Made in Japan.
Any ideas what's wrong or what I did to screw things up?
