I want to power a PedalPCB Intelligent Relay Bypass from 5v USB power.
Since the module in its standard format does actually run at 5v, stepped down from the standard 9v input using a 78L05 voltage regulator, is there any reason why I can't (or shouldn't) run it directly from a USB power supply by simply omitting the voltage regulator and putting a wire link on the pcb across the voltage regulator's Vin and Vout pads?
Thanks
Paulo
Thanks
Paulo
