Procrastinator LED dim in bypass etc.
unfun23
Hello!
This is my first post here, and I searched for previous solutions, but none solved mine.
I’m a relative noob so go easy on me!
The LED dims in bypass, but never turns off.
There’s also a large amount of volume loss when engaged. I assumed I had screwed up the grounding, so I tried a few different things and nothing helped. New switch, swapped the ground and switch inputs (switched ‘em back), reflowed solder, new led… I’m at a loss.
Any obvious dopey moves noticeable here?
I know my soldering needs work, but I’m getting better.
First photo is in bypass. Excuse the haze. Southern humidity is a bear on my camera.
Thanks! I’ve been lurking for months now…
