nicolasseveryns
Hi, I'm very new at this hobby. This is my fifth 'build'. It's the ROG Professor Tweed JFET preamp. It's a preamp driven by 3 JFETs.
I have breadboarded the preamp according to the schematic, biased all 3 JFETs at 4.5V and everything worked great. Then I decided to solder it onto stripboard according to a verified layout I had found on the the tagboardeffects blog. I managed to bias JFETs Q1 and Q3 to 4.5V. Q2 however keeps giving me a reading of 200mV. Turning the trimpot does not have any effect at all. I am measuring the voltage between ground rail and the drain pin. Doing the same with the other JFETs gives me 4.5V. The circuit however, seems to work. I get a nice tone out of it, only at overdriven settings it clips too early. I have checked all the connections, followed the signal. Everything seems to be fine, apart from the fact that I have made a mirrored build (beginner...).
What are my options? Trying a new build? Put everything as is in a pedal box?
My main question is why I managed to bias it on the breadboard and why isn't it biasing now?
Here are some pictures of the top, bottom of the finished stripboard, as well as a pic of the layout I based myself one.
Thanks for any directions/suggestions!
Top side
Top side
