maxamendel
This started as a question about the TL072...
Its evolved over the evening into a question about voltage regulation.
Theres a Rob Mods project to build a bass preamp. I'm doing a few of them. Since they're onboard, they're gonna need batteries.
On his website, he doesn't make it clear if he uses 2 batteries for 18v or just 9v. Lets assume its 9v. I do have one bass thats already routed for a single 9v and its staying that way, so for this discussion I'm assuming 9v instead of 18v.
At the front of his schematic, he has a voltage divider that brings the Vref down to 4.5v.
This connects to pins 3 and 5 on the tl072.
Is that necessary? Why can't I just omit the divider and tie pins 3 and 5 to the 9v power?
If I can't just use 9v, would it be beneficial to do a voltage regulator like the lm317 instead? I was thinking of doing that to get to 7v instead of 4.5v for the Vref.
I have a feeling this is a question about headroom, and voltage difference between 2/3 and 5/6 determine headroom, but im not really sure if that's right and if it is idk how to optimize that.
thanks for the help. its be going into an altoid tin, so I'll repay help for a build report and minty pics after im done. cheers
