dmnCrawler
Why is the ON/OFF switch a DPDT when it looks like it only uses one side? Couldn't the other side of the switch go to an LED? Then again it's early in the morning and I could just be confused.
Edit: OK I did a little more looking. [i.e. had some coffee] I was just wondering why both sides of the DPDT are wired together?
I also did a simple mod to get what I wanted. I am getting older and need all the help I can get seeing things. The holes is a perfect size for a 3mm LED. I just wired it under the board to the switch.
