Feral Feline
This pedal is basically a clone of the TC Elec Spark Boost.
From what I can gather, Iommi was apparently a Spark Boost user (according the TC web site), and somehow Laney got Iommi to endorse their clone of it.
It's definitely not an amp simulator, but it is a nice boost pedal.
Yeah, I know exactly what it is, that's why I suggested it:
Dark Esbat with the Sabbath and the ELS SuperTrouper.
OP is going for "Iommi" tones, so there's a bunch of stuff out there to help get those tones beyond just aiming strictly for an AIAB pedal.Maybe the OP can get to the sound in his head via a combination, 'cause let's face it — pedals can never replace an actual amp, but we try to get close to it.
@Diego
Here's a nutter tingetje to thinker 'bout:
Just as ICTRock pointed out in post #17, "you don't bias mu-amps like you would single jfet stages", and accordingly you don't bias JFETs as you would tubes.
I bring that up because I noticed you've got the SuperGroup amp schematic (well, preamp) amidst the other schematics in post #16 — while certainly the amp schematic needs to be referenced, it is but a launching point to get the sound you want.
For instance, many people will favour mu-amps to emulate an amp's sound, however Bajaman favours using op-amps and has many circuits emulating various amps — his emulations have become popular within the DIY community. Several amps he's emulated with op-amps having been also emulated by others using JFETs or Mu-amps — whatever it takes to reach the end goal/many ways to skin a cat.
Back to JFETs as tubes and Mu-amps — I've read some interesting notes about how the Ampeg B15's tonestack is wrong in many AIAB-pedal clones of the circuit because the cloners didn't SCALE the tonestack's values down for the emulation. Check out the Ginger link below.
Think of it like cooking chilli for 500 people or just 5. Do you use the same amount of ground jalapeño for both batches of chilli?
An amp is dealing with mega wattage/volts, so scaling things down for a 9v pedal that isn't using tubes... well, some things have to change.
I recently ordered the Lemon Rockerverb PCB from Guitar PCB Mania and I'm really excited to build it. Recently, I built a Sabbath from Pedalpcb. I was wondering, how does someone take a schematic of a tube amp and then convert the preamp section to a transistor based pedal?
I have wondered this for a while. It also raises other questions as I was looking into building some other higher gain pedals. Is there a particular reason that pedals like the BE-OD and Revv G2/3/4 don't use transistors to replicate their amps preamp? Is it more about the voicing and using standard clipping options...
- megatrav
- Forum: General Questions
How many times do we see post in the Troubleshooting forum where the problem turns out to be a JFET?
Like Germanium transistors, JFETs are finicky beasts and buying the right part number does not guarantee success.
First, a very brief primer on how JFETs work.
JFETs are voltage-controlled devices. The drain current depends on Vgs (the voltage between gate & source). The gate current is so close to zero that we can safely assume it is zero. We'll talk about N-channel JFETs (arrow on the gate pointing in) because 99% of the time that's what are used in pedals. When Vgs is zero...
- Chuck D. Bones
- Forum: Chucks Boneyard
Here's a comparison of most of the JFETs we use in pedal circuits.
I pulled 5 samples each of 15 different part numbers. I measured Vgs,off and Idss. From that, I used the JFET formula to calculate the Vgs and gm (transconductance) at Id = 200μA. I chose 200μA because that's a typical drain current for pedals. Some pedal circuits run the JFETs at a much lower or much higher drain current. It's easy enough to recalc the Vgs and gm for any drain current between 0 and Idss.
This is a small sample size and does not represent the full range of Vgs,off & Idss that we might experience for a...
- Chuck D. Bones
Runoffgroove Ginger
Collection of vero (stripboard) & tagboard layouts for 100s of popular guitar effects, with over 1000 verified designs. DIY your own boutique effects!
TLDR: Don't get too hung up on minutia, trust your ears.
