carlsoncoder
I purchased the following pots from Tayda for use in an enclosure for a PCB I'm building:
https://www.taydaelectronics.com/p-...taper-potentiometer-round-shaft-pc-mount.html
If you look at the picture, you can see that there is a little metal tab that sticks up. There appears to be another metal tab on the other side, that is folded down. I'm also posting my own picture here that might make it more obvious:
I tried putting a washer/nut all the way down the threads, but the tab is still 'higher' up than that. The problem this seems to cause, is that when I put the pot into the enclosure, it's not flush/level against the inside of the enclosure - since one side is flush but that extended metal tab isn't letting the other side go flush.
I've only dealt with pots when installing guitar pickups, and don't ever recall this extended metal tab. What am I supposed to do here? Add a few extra washers to the bottom so I get the nut higher than the tab, so then the nut would be flush on the inside of the enclosure, not the base of the pot? Or can I just clip/trim that tab?
Really confused - any help would be appreciated!!!
