I'm looking to order the pcb and source the parts for a Deflector. I wanted to make sure I know what I'm getting into, as it is my first FV-1 / EEPROM build.
From what I can tell, the build is straight forward given:
Thank you,
Dan
- I'll order the FV-1 pre-soldered with the PCB, to avoid having to source and solder
- The build instructions say IC3-24LC32A is included with the PCB. I assume it is programmed and ready to go.
- All of the other components including the other 3 IC's are easily sourced parts at Mouser, etc.
Thank you,
Dan
