SOLVED Rangemaster and Muffin Fuzz 2-in-1 with Order switcher
cniers13
I recently finished up a Muffin Fuzz (Mask Us variant) and Rangemaster treble boost. I followed the 3PDT Order Switch Wiring and I'm getting bypass tone but when I engage the fuzz I get nothing and when I engage the boost I can hear a very faint signal with the knob all the way clockwise. Any ideas? For the order switcher, I have an On-On 3PDT Toggle from Tayda. A-1955 is the part, but I'm not sure if that is the issue. No LEDs yet, waiting on my order to come in 1747238259095.jpeg
Start with the simple things
Are you sure you plugged into the input. Easy to mix up late at night with an upside down pedal.
Double check cap values in the muffin. Particularly the film in elcro spots. 100n and 100u could be mixed up.
Cap values are good. And verified that I am plugged into the input
Checking for shorts is really the next thing for sure. It sounds like the rangemaster may be functioning but misbiased, or something is shorting to ground.
May be worth checking the poles on the order switcher for continuity.
An audio probe is really your best tool once the eye test has passed.
