Recommended components for JLCPCB assembly process...
LukeFRC
TLDR version: First time getting trying JLCPCB's assembly service ...
1N4148 in SOD123 size
0805 125mW resistors
0603 50v MLCC caps
SOIC-8 TL072
Will be ok? Anything I should know for SMD layout that I don't know yet?!
Large 1m resistor, power diode, film and electrolytic caps, pots and switches will be through hole
Longer version: I have a small pedalboard, There's a pedal I want to make, PedalPCB's version is too big, and Fuzzdog's version has the sin of sidekicks - so playing with the idea of designing my own board (not my first time doing this) and going for a tiny Gorva M45 with top jacks.
Version one of the layout was all through hole and looked like Manhattan with everything stood up but then I had the thought that I could try the JLCPCB assembly service. I have googled, I have searched and read this forum, reddit and wherever and read up on things to avoid in SMD component choices *think* the sizes I'm using will be fine.
Any help or advice gratefully received!
actually ignore me - I actually think buying the musikding kit works out a similar cost for a lot less work. If I was making a small batch it would be the way to go I think.
