Audandash
- Build Rating
- 5.00 star(s)
Today’s pedal to mark off the list? The Aionfx Redshift phaser. I generally like phasers and who doesn't like switches? This certainly has a lot of the latter. Its a pretty simple build it just takes a little effort to get everything lined up with the enclosure. I ended up tacking in one leg of the pots to hold them in place. Next i did the same with one of the dpdt switches to get the height right for them. After that it was easy. I just mounted the switches to the box (making sure not to confuse the on off on switches) and the board laid down right at is was supposed to. I will likely go back and tuck the wires underneath to make it look pretty but it was more of a function thing this morning. Fired it up and it worked first try. I got to play with it for a few minutes and so far I like it. I like being able to have two set rates to toggle back and forth. If anyone needs the Tayda drill template it’s verified now.
