cyborgdiaspora
I'm trying to figure out a way to make a switchable buffered splitter where two inputs can be routed to two outputs in all three possible combinations. This would be used with a guitar that has both mag and piezo outputs, with the idea that I can split the mag signal, split the piezo signal, or keep one of each. I am also hoping to control this device via a relay switching port on an MC6 Pro.
This diagram represents what I've come up with. The idea is that S1 and S3 would select between "bypass mode" or "splitter mode". Then S2 would determine whether "splitter mode" would split input 1 or input 2. S1 and S3 would be controlled by one remote switch while S2 would be controlled by the other.
I am planning to use this kit for a TL072-based buffered splitter and these pcbs for latching relays. I figured I should post my relay question here since this is where I'm getting the relay pcbs!
In order to get S1 and S3 controlled by the same remote switch, do I:
-Use one control circuit for both S1 and S3, then wire the coil pins from both relays in parallel? Or in series?
-Make a separate control circuit for S1 and S3, but have both control circuits wired to the same remote switch?
-Some other option?
-Some other option?
