Removing DOD buffered bypass
NOC
I have the schem for the DOD 515 Sustain circuit (Comp + Dist). There doesn't seem to be much info on this guy, but I wanted to try to lay it out in Eagle without it's buffered bypass switching. The schem is fairly straight forward, but I'm not sure what components are being used for the switching.
Thanks! I assumed it was the CD4007 since it has been used for switching by the great RG Keen. It's also attached to the switch haha. Would the slow turn on circuit be necessary for true bypass?
The slow turn on should be able to be removed. But like I said, I'm not an expert. I would guess that they went to all this trouble for the bypassing (and slow turn on) to avoid pops/clicks. I'd definitely breadboard this thing before starting on a board.
Reactions: NOC
