So I built both the Revision and Loneking overdrives - the problem is that I like them both. So I wanted to build one TS pedal with all the options from both pedals mashed into one.
I figured the Revision circuit topology was the best starting point, since I think it would be too hard (impossible?) to shoehorn the 'Bite' control into the Loneking circuit.
The only thing you have to put into the Revision is a body control and the Voice toggle. The Voice toggle is easy - just put R9 on a switch.
My question is for the Body control - is there any reason why the below schematic wouldn't work? I would have to put the Body pot (along with C14 and R20 taken from the Loneking) branched off the same point as C6, and then connected to the same ground point as R9 (the bit in the middle of the schematic with the dashed box around it), which is not how the Loneking is set up.
LTSpice says it will work, but I was hoping for a second opinion before I commit to it, build it, and then spend 4 days tracking an error that I'll never find because the circuit itself doesn't make sense.
