Rockman X100 Rev. 10 Schematic Release
@Cybercow thanks so much, that's really helpful.
I've been working on reversing the x100 myself for some years as a side-project, and I just finished schematic capture of two units. I'm planning to go to PCB creation and build next, using parts I've sourced over the years (including some MN3011's I bought from that same seller you were using).
I just so happened to stumble on this thread yesterday, and it was great timing to check my work against a much larger effort. The LEDs were the last piece of the puzzle, I'm glad to hear you can get the circuit going with a properly spec'd modern LED.
With the successful completion of the (Rockman) RMS X100 Rehouse Project V1 & V2, Josh Ledford and I are happy to finally release the fully corrected Rockman X100 Rev 10 circuit schematics. Over the course of almost four years, as many as four people have collaborated with analyzing, testing, measuring and drawing out the many details wrapped inside Tom Scholz’s signature sound circuit.
The original schematics found on the US Patent site are by no means complete, accurate or even workable when compared to what we eventually discovered with all of the analysis we’d completed on over 2 dozen Rockman X100 units. The attached schematics are accurate, tested and verified as we’ve produced over 40 of the RMS Rockman X100 builds.
(The blue component IDs are those IDs used on our V1, V2 & V3 PCBs. The IDs in black are those used on the original 1980s X100 rev 10 boards.)
View attachment 57022 View attachment 57023
The first 18 months or so was spent on analysis, schematic corrections & creation, cloning the original PCBs and parts sourcing. The original concept was to simply rehouse an X100 into a pedal with foot switches for faster access to MODE & FX changes. After producing a working set of PCBs, populating and successful testing, the next step was to sort out how change the slider switches to stompswitches. But the stompswitches available are just insufficient to meet the complex switching arrangement Scholz used in his units. That was about where I came on board to help with a working, reliable switching system for these pedals. Old school sequential logic switching proved out to be the easiest approach without having 8 or more stompswitches on a pedal to accommodate all the MODES & FX. So, one stomp to cycle thru all four MODES and and one stompswitch to cycle thru the three FX with an added “Dry” option (no FX). Naturally, a true-bypass 4PDT stompswitch was included to facilitate the mono-in/stereo-out circuit.
Another discovery with X100 prompted us to develop a unity-gain recapture circuit, as the X100 is a below-unity-gain circuit. So with the switching and output levels to manage, we added the ‘sequential logic switching’ and ‘low-level output’ (LLO) circuits.
View attachment 57024 View attachment 57025
There is a lot to be said about the differences between the original Rockman X100 and the updated V3 units we are about to produce. The evolution from the simple “rehousing” idea to the latest RMS Rockman X100 V3 is another long story that will also unwind as time allows.
With the disappearing availability of the MN3011 BBD chips, we will drop the use of the MN30xx BBD chipsets altogether and use the SpinSemi FV-1 DSP chip. This greatly reduces the overall noise, large footprint & parts-count of the PCB. And it allows us to go with a smaller, more readily available 1590D enclosure, using the same sequential logic switching for the MODE options. The FV-1 FX switching will be a standard SP8T rotary switch. About 6 months was spent in learning and developing the FV-1 FX patches to match the original X100 FX sounds. The bonus with the FV-1 is that it allowed us to add 5 more unique FX patches to the Rockman sound. And we already have a working prototype of the FV-1 infused V3.
View attachment 57026 View attachment 57027
For the most part, all is said and done. Except for the completion of the V3 portion of this massive project.
Just bought one of these off EBay for like 400 dollars didn’t even come with the power supply. But I have sufficient resources to make it in my evil laboratory.
Has anyone had boards made?
My pedal building “rabbit hole” started with seeing someone on Youtube building the “Mockman.” Back when I started my first real job, I had the opportunity to buy a new Rockman X100, but settled on the Hot Watt II, which was lost to the sands of time. Now 20 some pedals later including the Mockman, PedalPCB Rockstar, and Pedal PCB Proposition (twice), I am still trying to chase Tom Scholtz’s magical sound. outside.JPG Inside crop.JPG
Using CyberCow’s corrected schematics and buck power supply along with bits and pieces from freestompboxes.org, I made a poor man’s pedal version of the Rockman X100 distortion/edge/EQ 1. Even this part was not easy to build, and lots of strange behavior during troubleshooting until I worked out some bugs and a cold solder joint. I auditioned several J201’s, but I’m still not sure the sustain is as good as it could be, but definitely there. Side by side with the Proposition, they are similar to my untrained ear, but the X100 sounds slightly brighter. I wasn’t quite sure how to end the partial circuit and add volume control, so I put a tonetweq on the tail end, which provides some minimal EQ adjustment. But the rabbit hole goes deeper, I’m already gathering some more parts to make a second version including the clean channel and both EQ’s. I also have a Caesar Chorus partially soldered up to avoid trying to duplicate the X100's Board 2.
Many thanks to CyberCow and the numerous other people who have spent many hours reverse engineering the X100 and freely sharing information with the community!
Cybercow
Hello, and congratulations on all your work and thanks!!
I am only interested in the Rockman Chorus and Echo portions. I have tried re-creating the Chorus schematic on more than one occasion with no success. I really want to get the circuit working but I am almost done trying. I do have MN3007 chips, and created a test rig to test the 555, and 4013 chips. This has stumped me now for aver a year.
I did not read this whole thread, but I did see that you look to have used a FV1 to re-create the chorus and echo effects.
Is there anyway that you would sell tha patches , or the chips with the patches loaded to use?
Thanks
Rob
Cybercow
Thanks
Rob
Thanks! Eventually, I will be posting the X100 FV-1 patches here in the PedalPCB forums. They are not yet settled for an X100 build using an FV-1. I have them for the Binaura, but not for an X100.
The Chorus is actually easy. An analog equivalent is a modified EHX Small Clone with specific settings, and set up for stereo output. The stereo output for the chorus is just an offset mixing for Left & Right outputs. One side passes thru a 39K resistor while the other side passes thru a 220K resistor. (See the effects side schematic of the X100 at the top of this thread.) The "ECHO" portion of the FV-1 effect that replaces the MN3011 is a bit more complicated.
Thanks for the replay!
I ordered a PCB for a EHX small clone and still waiting for it to arrive. Anyway I can get your final schematic for the what you did on the chorus?
That was my intent to use the Small clone and try to convert it, but the clock is using a 4047 instead of the 555. I do not know enough to know how much this will effect the overall chorus effect.
What I failed at trying to suggest is instead of trying to re-invent Tom's Chorus circuit, is to replace it with a modified EHX Small Clone circuit. And that depends on whether you're trying to do a separate chorus circuit or integrate one into the complete X100 circuit schema.
For a stand-alone chorus circuit, I use the GuitarPCB "Mini-Me" PCB. It more readily lends itself to easy mods.
As far as using a 555 or 4047 goes, it doesn't matter and shouldn't affect the chorus sound, as it only supplies the clock for the BBD chip. I suggest looking at the "Mini-Me" schematic and comparing it to the chorus section on the X100 Main Brd schematic.
Got home. The original X100 PCB Gerber are attached.
There are two and are named:
1) X100_Rev_10_Main_Brd_Gerbers.zip.pdf
2) X100_Rev_10_FX_Brd_Gerbers.zip.pdf
Just strip the ".PDF" from the file names and you have standard Zip files ready for submission at JLC.
Mighty kind of you to share those Gerbers, Cybercow. Many thanks, may your digiworld pastures be vast with plenty of binary-grass and clean cool hydro.
What sets the delay time in this circuit? I want to create a separate chorus pedal based on the LFO circuit for the modulation. But, as I am trying to learn chorus circuits I cannot find info on the delay portion. Electro smash does a great job explaining the circuit portions of the CE1, but I am finding it hard to figure out how a chorus circuit makes the delay time
The secrets of how chorus pedal sets the delay in the chorus is found in the specific BBD chip's datasheet. The timing chip merely establishes a clock to drive the chorus BBD. The delay in chorus is pretty much fixed to a short, specific delay range in order to keep within the parameters of what constitutes a chorus effect.
Are you wanting to more about how the X100 generates its chorus or the CE1?
X100. From what I have read the delay is 20-24ms, and the modulation is between 17-23ms.
I looked at the data sheet for MN3007 and the delay time is adjustable between 5.12-51.2ms and represented by tD. But I do not see on the data sheet how to adjust this time?
I just read that the delay time is determined by the clock frequency used to drive the MN3007.
I am trying to figure this out so I can try to use something other than the 4013/555. Like maybe just a 4046.
I'm sorry if this is a dumb question but how do I strip the .PDF from the files? I am stumped. I suck at computers. I tried renaming it but the .pdf doesnt appear there when I rename it.
