MichaelW
Well, I'll be the first to throw this up.
It's not "DONE" as the distortion side isn't working and I haven't had the chance to figure it out.
But since we're looking at the behavior of the phasing I thought I'd focus on that.
I initially biased according to the build doc, -1.35v but I wound up biasing by ear to get the best phasing. I found the exact opposite of the build doc in that small adjustments on the trimmer make a pretty big difference in the phasing. I wound up somewhere around -1.78v.
Having said that, I have some oscillation that modulates with the phaser even when not playing. I can't seem to dial it out with the trimmer.
It "could" be dirty power at my house.
As far as the phasing itself, it sounds good. Using the 4 stage it sounds somewhat like a Boss PH-1r. 6 Stages is pretty cool and may be my favorite setting. 8 stages gets into Mutron-ish land.
Regarding the "thunk", @aion can you be more specific about what the issue is? Or point to a clip on the issues?
I'm not hearing anything like a clunk, or a hiccup at the bottom sweep if I'm understanding correctly.
Couple of tips.....if you haven't built it yet.
For Q12, use the 9th JFET that Kevin sent to you. I tried a TO-92 2SK208 initially and wasn't getting any phasing. I popped the JFET that Kevin sent in and it fired right up.
Secondly, Q11, if you're using the Interactive BOM it calls for a 2N5088. The build doc says to use a 2N3904. Use the 2N3904.
It SHOULDN"T make any difference between these two options but in my build, for some reason it did.
