PangeaDestructor
Hi, I've got a few boards from RW nearing completion, the King Tut is up first. However, I didn't order any of his 3pdt breakout boards and I'm not entirely sure how to wire up the footswitch, especially with the LED. I emailed him for a diagram but haven't heard back yet, any help on which pads to which lugs would be much appreciated.
Also, his LEDs are wired from the breakout board which has a 4k7 resistor. I've only ever wired LEDs directly to the board, do I hook it up to a 3pdt lug and do I need an inline 4k7 on the anode?
3PDT Breakout Stomp PCBs (4pcs)
True Bypass 3PDT breakout boards. Solder this onto your 3PDT stomp switch and simplify your stomp switch wiring. Compatible with all Rullywow projects. Make your builds neater and simplify wirin…
rullywow.com
