greypilgrim76
Hi All,
As you may have seen in this thread, I recently ordered some MP38A transistors off eBay to build a Muffin Factory. After testing them out, I found that two of them were ideal for the MF, but the other four tested pretty well, too, and I'm wondering about using a couple of them to do an old-school style fuzz. In sorting through the fuzz options available, I noticed the Sandspur Fuzz already calls for NPN transistors, so I'm curious how much (and what kind of) tweaking would be necessary if I replaced the BC108s with MP38As, or if there's a better PCB to work with using these transistors. If it is something that would work, I'm also wondering which of the remaining four transistors would work best. Here's what I've got:
#1: .13 mA leakage, 62.3 hFE
#2: .15 mA leakage, 60.4 hFE
#3: .25 mA leakage, 71.5 hFE
#4: .19 mA leakage, 82.2 hFE
I'm not sure if there are other things I should test, or if there are other components I'd need to adjust or swap out, so I figured I'd just check and see if some of you with more experience/knowledge in this department had any advice.
Many thanks!
Many thanks!
