Scenario Preamp + Synopsis Overdrive (Gladio)
GazM
My first time doing 2 in one pedal enclosure, worked out great and followed the guidance on the wiki page. Used a 1590XX enclosure, graphics UV printed by Tayda. I did make one cock up, where I drilled the jacks in the center of each pedal as I had so much space for two jacks, but then after drilling realized it clashed with power wires from the PCB, so ended up now with 4 jacks, only two being used 🤦‍♂️. Its ok though, looks like a stereo pedal on the outside and I just need to remember the outside ones are the live ones!
Just been playing it, sounds ace. I need some more time with the pedal but I prefer compression on on the preamp, and the rock and open settings on the drive. great range though and sounds killer when both engaged. I haven't played with the trim pot inside yet, but I'm happy with the bass as it is, but will likely tweak that over the weekend when I have time.
Artwork is a blatant Banksy rip off!
Thanks again for the pedalpcb team that made these two available!! :-)
