Feral Feline
@Ginsly
I didn't have time yesterday to look into it, but I vaguely recalled some BJTs that have wacked pinouts (compared to other BJTs).
Here's a BJT with a TO-92 package that has a BEC-pinout:
Mouser Datasheet for FAIRCHILD KSP10 PDF !
OnSemi took over Fairchild and lists the KSP10 as still active, here's the OnSemi KSP10 datasheet PDF; so you should be able to get some KSP10 from Mouser or elsewhere.
Since I'm already at it, Mouser has two versions:
The BU version has 7,000+ straight legs in stock, and is 35¢;
The TA version has 7,000 pre-bent legs in stock, cheaper at 32¢.
As per this thread on Electronics Stack Exchange, I also recalled there being Japanese Epitaxial Silicon BJTs with the BEC / CEB pinout;
that's also where I found reference to the KSP10 above. In the thread, the KSP10 is compared to a 2N4401, here's the datasheet PDF.
Further to the 4401, the original Intersound IVP Preamp called for a few 4401 — Aion's IVP take subs out the 4401 for a 2N3904, a very-common middle-range BJT, one of my favourites due to its low cost and ubiquitous availability.
Other circuits with 4401: PPCB's Duophase and Loft Fuzz, Moonn's Dice, EAE Beholder, ApeTone's 280KG Gorilla, Madbean Glasshole and Retrograde, LG Hazy Octave, GPCB OKF... loads.
Years ago, before Barbershop PCBs were readily available and before I knew what I was doing (alas I still don't know, but...), in 2018 I built a pseudo Barbershop on a GuitarPCB Red Special. I had noticed the basic skeletons of the two circuits' schematics were the same. The notable difference is in the transistors...
Barbershop is JFET > JFET > BJT
(J201s x 2 and a 2N2222)
Red Special is BJT > BJT > JFET
(2N5088, 2N3904, and 2N5457
I found the 2SK117 had the pinout I needed for putting JFETs in the Red Special's BJT positions, but then I had to bend legs of a 2N2222 to fit the BJT in Q3-JFET position of the RS.
My research revealed the 2SK117 is a pretty good sub for the J201, and now 6 years later I find the KSP10, a comparable sub for the 2N2222 — it may put an end to the bent legs!
I'll be picking up some KSP10TA myself, next Mouser order, and then hopefully I won't have to mangle legs on Q3 of future Red Special Barbershop builds.
Meanwhile, I'll hunt a while longer for some more BEC-pinout BJTs.
Please let me know if you find any others.
		 Sourcing, Substitutes, Etc"
