SOLVED Sea Bed Delay with Bon Tempo (tap tempo) grounding issue???
hdansin
So I finally got everything together for this Sea Bed Delay with tap tempo. Got it working downstairs on a daisy chain power supply, then brought it upstairs to my pedal board with an isolated supply and got no output (not even passthrough). I had a weird grounding issue, where I had to tape the input and output jacks where they were making contact with the drilled holes of the enclosure. When they touched the metal of the enclosure it would mess up the circuit on the bontempo, so I had passthrough, but nothing on the bontempo worked and I lost control of the delay. I taped over them and installed the jacks and everything works on the daisy chain supply, but not on the isolated supply. I'm wondering if anyone here has insight into grounding issues with an enclosure like this. Is it because the bontempo and seabed are sharing a power jack? Is there anything simple I'm missing?
Bontempo datasheet: https://electric-canary.com/products/bontempo/bontempo---datasheet.pdf
I am very aware that it is a messy build due to my subpar wiring skills (and the hot glue); and the hubris of trying to fit this in a normal enclosure. What's confusing to me is that it works perfectly on the daisy chain, but doesn't on the isolated supply (I tried both 100ma and 500ma on my isolated supply). Any help is much appreciated!
signal-2026-10-25-13-38-55-093_002.jpg signal-2026-10-25-13-38-55-093_003.jpg
