I did not have any oscillations. As I originally posted, I found the boost to be only slightly stronger than unity gain and it cuts some low end frequencies.
Risk of oscillations is why I use a Cliff jack on the input (limits the chassis to having a single source to ground, the output jack) and I run the wires from the jack as far from the circuits as I can.
I had a problem like you describe with a Lead Solder PCB build, where the original gain circuit was too much and would begin to ring (howl) with the mids all the way up.
