Svenson007
Hey there fellow pedal nerds
It’s been a while. So I am building a Simulcast for somebody. It’s all together (not boxed) and tested. It sounds fantastic with some Toshiba germanium’s I salvaged out of a Hammond organ a while ago. Those things are like a gold mine.
The problem I’m having is with the low cut and biasing? Once I get down to about the last 1/4 turn of the pot it starts to fart out and sound severely mid biased. All the way down yields zero signal. Right before that it sound like a crackly mess.I’ve built a ton of Duocasts and never had a problem
I’ve read somewhere that the circuit doesn’t tolerate leakage well. So I tried a couple other transistors yielding slightly better results.
Is this really just a keep trying transistor until all is well? Or should I be focused on the biasing resistor. Not sure which that is, I haven’t had a peak yet. Also I’m not the best with schematics compared to some of you guys. I also considered trying different pots, but not sure how that would work out. And since it’s for somebody else I want all the correct values. If it was a personal build I wouldn’t mind quite as much as I don’t use much low cut.
Anyways. I’d be forever grateful if somebody could shine some light on this. Whether you have built it or now.
Edit- This build is using the old V1 style pcb if that matters.
Thanks so much guys.
