skeptical buffer eq switches
What exactly are the boosted frequencies for each switch on the skeptical buffer? And, if I wanted to change those frequencies to be more suitable for bass, which resistor/capacitor values would I change?
Each switch turns on/off a different corner frequency in either opamp in the screenshot below. I highlighted R6 since you will need to take that into consideration when calculating the corner frequency (they are parallel resistors here for the first two switches). Keep in mind if you change R10 you will also change the gain structure of that stage: if you increase the value you will decrease the gain and vice versa.
