pcb rookie
Practice builds confidence. I did more soldering lately and got better at it overtime. I did some pretty clean PCBs lately. Most days the solder just flows through easy peasy. Every now and them, I hit a project that the solder just won't flow right. Today was one of them. The solder would stick to the lead instead of flowing though/on the contact eyelet or just bunch up. I stopped, cleaned and tined my tip. Cleaned up the PCB with IPA. Tried again, same. Applied some flux paste (usually don't). It got better but barely. Flowed perfect in the end when I got to transistors and trim pots ...
Any one as leads on what's the cause when solder just won't flow?
When do you do or adjust when that happens?
FYI - I use 60/40 Aims .032 diameter solder @ 400 degrees average. I tin my tip between every 2-3 solder and keep in clean.
