I’m planning on doing a fuzz foundry deluxe into a tone vendor mkii into an as to yet undecided muff variant. I’ve built about 15 pedals but this is my first multi pedal build.
I’m currently planning on fitting 3 of the pcbs in a 1590DD. Is there any best practices or special considerations I need to make with a multi pedal build? I understand the simple wiring needed to do this.
Are there any handy tricks to horizontally line up the separate drill templates? I’m almost tempted to just measure out the desired pot locations on the pots nearest the edge and the center for the led on the tone bender.
I’m planning on having an effects loop between the tb and the muff. Maybe for a tuner or a rat I dunno just seems potentially fun. Am I fine just wiring up switched jacks to pass the signal with nothing plugged in or should I squeeze in a footswitch?
