Hi,
Since I can't really read schematics (yet), I may be asking something stupid here, but here goes anyways:
Can I mod my Southern belle (=Greer Southland) to have smaller gain range? I've noticed that with gain between 9-10 o'clock it provides a tighter/more focused alternative to my Greer Lightspeed in its higher gain settings. With these settings, the two aren't miles apart, but I've found uses for both. With the gain set low on both, they also work together quite nicely.
The Belle, however, has such a Hhuuge gain range that dialing in the right low/low-medium gain tone moment can take some time. That makes me wonder if it's possible possible to reduce the gain range that the pedal has? With the way it is now, the sweet spot is usually found between 9-10 and I can't imagine ever going beyond 11 or noon. (I think the higher gain settings don't sound too pleasant on this pedal.) Could this mod as simple or changing the 1M gain pot to, say, a 500k one? Or could I achieve the same effect by soldering a resistor to the pot or something? These two have been suggested as solutions to decreasing the gain range in other pedals, but if I've understood correctly, whether this works or not depends on the schematics of the pedal.
(I also have a Mach 1 pcb at hand as sort of backup for my Lightspeed. If you can suggest a mod that would tighten the Mach 1 / Lightspeed a bit, I'd be interested to hear about that, too. I understand those two pedals are more or less the same with only minor differences.)
Thanks for help. Really appreciate this community.
