Show a good Picture of the Resistors & components to see if there are wrong values.Just finished the Sproing Deluxe. Everything is working except the gain is below unity even when the gain pot is maxed out. I used the VTL5C3 - Xvive VTL5C3. I tried changing the 220k resistor to 390k and then 470k. Any thoughts on what to try next?
It's been probably 4-5 years, but for what it's worth... I had the darnedest time with my Luna build. Ended up having to take it to a pedal wizard friend of mine and he tested and ended up using a different vactrol and something else. Sounds great, but I have no idea what he used. That being said, I also was having an issue with my Sproing Deluxe and just put in a orange diffused LED with a 5516 (recommended in the Pendulum), and it sounds great! Unity is just a smidge below max gain. Therefore, if I want it to thump harder it can... but I'll keep it at unity 99% of the time. Good luck.Thanks. I went with the vactrol based on these comments from Aion:
"The Luna sounds best with a VTL5C3 workalike. Since the original VTL5C3 is no longer made, you’ll
likely need to find a substitute. Xvive and CoolAudio make their own version under the same part
number, VTL5C3, and both are available from Small Bear Electronics as well as several international
retailers. Alternately, Small Bear Electronics sells the Macron MI1210CLF-R which works just as well."
