D.M.N.
My #1 amp for...jeez, 15 years? has been a Sunn 2000s. Absolutely love the things, still have 2 that trade duties. I saw a schem and build for a 200s in a box recently, and thought "hell, why not the 2000s". The 200s build was a bit in between the two, as it included a 'mid' control, but left out some other parts of the 2000s. So I did some reading on JFET adaptations, namely the runoffgroove article, and came up with this:
Runs at 18v, will have a DI out, includes the bright and normal inputs for the 2000s, the bass boost switch, and I tagged an output volume on to be able to drive the front end and tame levels. I have J201s in the schematic, but figure I'd give 2N5457s a go as well. But there's two things I still haven't managed to figure out...
Any suggestions would be greatly appreciated!
- Scaling values. Per the 200s pedal adaptation, the pots were scaled down, but it looks like they retained all the other parts values. In the ROG article they mention all the grid and cathode elements stay the same. Per this thread, it is mentioned to scale the caps and resistors to adjust for impedance. In doing so, that should help reduce noise, is that right? So I should be scaling throughout the circuit for the resistors and caps?
- The spare leg on the Bass control. In the Sunn schematic below, it appears that the leg is left disconnected. It'd probably be better practice to tie that to the wiper, right?
