Tayda Print Review
CheapSuitG
The TubeSchemer
Hi!
I'm getting ready for my first Tayda UV print and wanted to see if anyone could give it a once over before I pull the trigger.
Big thanks to @Fingolfen or the Steggo tutorial, it is super helpful!
I started with the @Pachyderm template (appreciate you sharing that though I can’t seem to tag you here) and moved it to the Tayda sample template.
I’m having Tayda handle the drilling, so I’ve removed all the drill guides from the design. The enclosure will be gloss light blue and I’m using 20mm knobs. Still on the fence about using a white footswitch washer, I think it might tie the design together nicely.
Thanks!
