fxwiegand
Hey guys,
i made a template repository for creating effects for the terrarium. This should make it super easy to create a new effect. Simply go to the terrarium stand repository on GitHub and click on "Use this template". Then build both daisy libs (more details in the README.md), maybe change the name of you pedal and you can start putting down your own audio processing in the code. The template already takes care of including the terrarium.h and most basic LED and switch handling. It also includes a README.md template (inside the your_pedal directory) that makes it easy to let others know what each knob and switch does.
I also have an example with a reverb created from the template right here. If you are only interested in the binary for the web programmer you can download the reverb.bin right here.
Let me know what you think and also if you find anything that could be added to the template.
