I have written extensively about JFETs in this forum.
Vp is the pinch-off voltage, the gate-source voltage where the drain current approaches zero. Most datasheets refer to it as Vgs,off and it is expressed as a negative voltage for N-channel JFETs. As a form of shorthand, we usually express Vp as a positive number, with the understanding that it is actually a negative value for N-channel JFETs.
In other words, Vp = -Vgs,off.
The other thing you need to know is that the datasheet just gets you in the ballpark. The datasheet Vgs,off range is large and in nearly every JFET circuit, you will need to measure and select the particular JFET for Vp or Idss.
