This Week on the Breadboard: MOSFET Driver Redux
Last boxing ups of the year, and it's a goodie.... this thing rips!
Cheers @Chuck D. Bones here's my version of the MOSFET Redux, called Cowpoker. And it has some buzz to it indeed, it screams and has a ton of gain available, harmonics pinch easily of the board. Noice one!
Since I allowed for compensation cap (used 33 pF) I tried TL071, CA 3130 and I ended up using a Russian KR1408B supposedly workalike of LM308 chips. All sounded great but the Russian one had maybe a bit less noise on high gain, surprisingly.
SWEET! I didn't know they had opamps in Russia. Try an NE5534 if you have one. The LF356 on my breadboard is plenty quiet.
Where did you end up setting the Gain Trim?
I do have an 5534 will throw that in. I have the gain trim pretty low, because my age bracket doesn't cope anymore with too much of that gainy stuff... lol... It has plenty of gain as is anyway.
Great sounding for sure.
I got those Russian opamps outta curiosity and have them in some Rat style circuits. Do I hear a difference, I dunno, sounds good though and a bit of exotic fun why not. Love some of the Russiabn tubes. so why not opamps as well when it fits.
Just tried the 5534, the Russian chip still has a slight edge, the 5534 had a bit of hi end noise in it. Maybe the Russian chip is not as hi end audio and that might play in favour here? Not a big difference at all bt so far the Russian KR1408B stays.
Maybe try a bigger compensation cap on the 5534. Where did you get the YR1408B?
What do you think of the BASS & TREBLE control ranges? Are they OK or would you tune them differently?
100pF is a good start. The other thing to try is a larger feedback cap (C3 on my sch). My gut feel is the NE5534 and LT071 aren't noisier, they just have more bandwidth.
The eBay seller implies they're equivalent to LM308, but without a datasheet, who knows?
Finally got mine boxed up. Thanks to Stephan for the board and Brett for the beautiful box artwork.
The toggle switch pads on the board didn't line up with the box artwork, but that was easily fixed by wiring the switch to the board instead of soldering it directly. I had to mount the board higher, so I used solder lug pots and connected the pots to the board with some stiff solid wire.
This board has a shit-ton of gain. I run mine with the Gain Trim turned all the way down.
This is a v1 board. I did the "squeal reduction mod." It helped, but did not completely eliminate the squeal at high GAIN & VOLUME settings. I have some V2 boards and will see how they do.
The relay controller runs the Coda Effects code which toggles the relay when the stomp switch is released. I worked around that by swapping the switch with its 10K pull-up resistor. Now it toggles the relay when the switch is pressed. It got me to thinking about modding the code. Then I came to the conclusion that a microcontroller is complete overkill here and the 555-based relay driver is a better way to go when we don't need a bunch of fancy features. Below is a slight mod to the PedalBCB basic relay bypass. The open-collector DISCHARGE output (pin 7) has greater current sink capabilities than the the OUTPUT (pin 3), so I use that to drive the relay. This circuit is compatible with 4.5V, 5V & 9V relay coils simply by changing R4. C1 does not need to be film; aluminum and tantalum caps have a smaller footprint. The only time this circuit needs a regulator is if someone wants to run the pedal on something higher than +15V.
BTW, there is nothing magic about the values of R1-R3 & C1. I tried 1M, 100K, 100K & 220nF and they work great.
Finally got around putting a demo video for this together, thanks again for Dave pumping out all these fab circuits and tweaks!
Playing in the video thanks to my friends Warren Mendonsa from Auckland, also know under the moniker blackstratblues. Check out his music, he's an amazing player.
And yes, I'm still using the Russian chip in there...
crikey.
that’s rad.
definitely gonna have a go at breadboarding this one
