Olivier7960
I ordered a w20k pot … what is the code on the pot ? Mine reads b20k
You can't measure resistors accurately once installed, If they are parallel or in series with other resistors they give the wrong readings!I ordered a w20k pot … what is the code on the pot ? Mine reads b20k
Yes. You received the wrong pot. Re-order the W20k and you should be good if that is the only issue.I. Checked my order and it was for a w20k potentiometer. On the one I received it’s written b20k …. So it’s definitely the wrong one ?
On a side note. I recently built the hoof pedal and it didn’t work. Very frustrating but after inspecting the back of the board under magnification and light I found a very tiny micro bridge of solider connecting a resistor and capacitor that were next to each other. I could not see this without magnification but that tiny little issue caused my pedal not to function. This was build #41. So don’t be discouraged at all it happens to all of us, just make sure when trouble shooting to really inspect everything up close. Good luck.Hello
Thank you all for your input. Thank you Chuck D Bones for your comment I realized that most of my solder joints were not done properly. I didn’t think that the solder had to flow through the hole and cover both pads, I thought I needed to put on the down side only ( newbie !!!!!) with a little fiddling I found a technique to do it properly. But I couldn’t fix all of them so I’ll have to start over … at least I learned something ! Will be working on the promethium distortion soon it looks cool !
I don’t think Chuck was implying that solder has to necessarily flow on both sides in order to have a good joint, but that it may be a sign of a cold joint or not enough solder on the other side. That’s what visual inspection is for. I would check the pads that don’t have solder in the back and make sure they look good in the front.Hello
