Tone Stacks - Part 3 - Tube Screamer, HM-2 & Gyrators
Chuck D. Bones
Circuit Wizard
The TS, HM-2 and some other pedals use a type of active tone control that had been in common use in graphic equalizers for quite some time. In its most general form, the tone circuit looks like this:
R1 & R2 are usually equal, but they don't have to be. VR1 is often a W-taper pot, although with careful component selection it can be linear taper. Z is a generalized impedance. In a TS, it's a resistor and capacitor in series. In the HM-2, it's a gyrator (or two gyrators in parallel). In some graphic equalizers, it's a series R-L-C. This 5-band graphic equalizer was published in the October 1970 issue of Popular Electronics.
Q1 is an input buffer. Q2-Q4 form a rudimentary opamp. So you can see, this active filter design has been around for a long, long time.
The TS is the simplest, so we'll tackle that one first. The schematic below is from the LGSM. It's the same as the generalized circuit above, with the addition of R19 (which does next to nothing) and C5, which adds some extra hi-cut. Z is replaced by C6 and R7. The opamp's feedback loop attempts to keep the + and - inputs at the same voltage. When the TONE pot is at zero (wiper all the way to the left), C6 and R7 are in parallel with C5. R9, C5, R7 and C6 form a low-pass filter with a corner freq at 400Hz. No current flows thru the TONE pot because both ends of the pot are at the same voltage. The opamp acts like a unity-gain buffer. Now suppose the TONE pot is at max (wiper all the way to the right). There is still no current flowing thru the TONE pot, but now C6 and R7 are inside the feedback loop (along with R10). At very low frequencies, C6 acts like an open circuit and the gain is unity. At very high frequencies, C6 acts like a jumper and the gain is 1 + R10 / R7 = 5.55 = 14.9dB. The transition from 0dB to 14.9dB happens over the range from 725Hz to 4KHz. But C5 and R9 are always there making a passive low-pass filter at 720Hz. When the TONE pot is centered, the circuit is balanced and there is no boost or cut (except the cut caused by C5).
The freq response looks like this. Each line represents the TONE pot going from 0 to 1, 2, 3, and so on up to 10.
Notice how most of the lines are bunched together. If we change the TONE pot to W-taper, the lines spread out. Pretty obvious why most TS clones use a W-taper pot.
Now let's look at the HM-2 tone controls. There's a LOW control and a HIGH control. It's the same basic circuit as the generalized circuit at the top of this article, except there are two controls and the Z elements are made from gyrators. So what's a gyrator? It's a circuit that transforms one impedance into another. In this case, it turns a capacitor into an inductor. There are lots of ways to make gyrators; this is the simplest way. Some gyrator circuits use an emitter follower instead of a unity gain opamp. The Blues Driver is an example of that.
Without getting into the gory details, the circuit made up of R21, R25, C13 and IC2.2 simulates an inductor. The inductance is equal to L = R21 * R25 * C13. In this circuit, L = 2.24H. It's not a perfect inductor, it has a series resistance equal to R25 and a parallel resistance equal to R21. The gyrator and C16 form the Z element in the generalized circuit, with inductance L in series with R25 and C16. It's equivalent to one section of the 5-band equalizer at the top of this article. When we put an R, L & C in series, we get a network that has a resonant frequency Fr = 1 / (2*pi*sqrt(L*C)). In this case, the resonant frequency is 87Hz, which can make a peak or notch in the frequency response, centered at 87Hz. Here's what it looks like in simulation. The LOW pot is swept and the HIGH pot is at noon.
IC3 and the surrounding components form a pair of series-resonant networks connected to the HIGH control. The two networks are stagger-tuned (960Hz & 1.3KHz) to provide a wide peak in the treble range. Here's the High control sweep with LOW at noon.
Clearly, the HM-2 would benefit from W-taper pots. Alternatively, the pots could be lower resistance (B1K). All of the HM-2's gyrators are easily retuned to change the center freq and Q.
One more gyrator example: Blues Driver BD-2. The BD-2 uses a gyrator in the feedback loop of the last stage to create a bass hump around 120Hz. That gyrator is realized using an emitter follower. It works exactly the same as an opamp-based gyrator.
The freq response of the last stage looks like this. Green trace: stock response; indigo trace: modified response.
The mod makes the pedal's overall freq response extend deeper into the bass region. The mod consists of increasing C17 to 330nF, decreasing C18 to 6.8nF and increasing R20 to 4.7K.
The gyrators we have been studying in this article all have one end of the simulated inductor at AC ground. That works out fine because where gyrators are used in pedals, that's what we want. It's possible to make a gyrator where both ends of the simulated inductor are floating, but it takes two opamps. In all of the pedal circuits where gyrators are used, the simulated inductor is part of a series-resonant R-L-C network. The resistor on the output side of the opamp (R25 in the HM-2) is the R in the R-L-C network and its value is chosen accordingly. That resistor determines the network's impedance at the resonant frequency. That R and the L/C ratio (C is C16) determine the Q. There is interaction between the Rs and Cs, but with two resistors and two caps to play with, we have enough degrees of freedom to tune the network any way we like.
There's no free lunch and gyrators have their downside: they can be noisy. Referring to the top gyrator in the HM-2 circuit, The R25/R21 ratio is the "noise gain" of the circuit. That means the opamp's inherent input noise is multiplied by the noise gain. In this case 100K / 330Ω = 303 = 50dB. That's pretty much the practical limit for pedal circuits. The Q of the inductor is determined by the resistor ratio. I tried to make a high Q inductor for a CryBaby using a gyrator and it was very noisy because the noise gain ended up over 60dB. This explains why nobody uses gyrators in wah-wah pedals.
cooder
Thanks!
My head hurts, just a bit, but that's a good sign.
Something must be moving in there and hopefully falling into the right place... ;)
fig
Village Idiot
Great stuff! I'm here for that! (learned that from a younger person...apparently all the rave)
Man, that is a dramatic difference between tapers.
What is the benefit from simulating an inductor over using say....an inductor?
Chuck D. Bones
Circuit Wizard
Good question.
Real inductors:
  • Can be bulky
  • Can be expensive - Wah inductors sell for about $10 on up
  • Depending on the value, can be hard to get
  • Can be constructed with very high Q (low resistance)
  • Are the only electronic components you can make yourself
  • Can handle high current and high voltage
Synthetic inductors:
  • Can be constructed for any value
  • Are potentially noisy
  • Are lower Q (higher resistance)
  • Are easily tweaked
  • Are fairly compact
  • Are inexpensive - under $1
  • Are for small-signal applications only
cooder
The DeadendFX TerraHawk (adaptation of the The S. Hawk Ltd. Hawk II Tonal Expander) uses inductors for tone shaping.
https://www.deadendfx.com/product/terrahawk
Unfortunately as I looked for one of those inductors they were out of stock at Mouser until 8 months away, which is how much in dog years again?!?
I love me some Rory Gallagher....
Reactions: fig
Chuck D. Bones
Circuit Wizard
If it's the same as this one, then the inductors are easily simulated with gyrators. R9 should be on the other side of C8. What is that LPF switch? Toggle, DIP sw or stomp?
Chuck D. Bones
Circuit Wizard
My breadboard to-do list is getting longer & longer. It's a good thing.
First, I'll simulate the Hawk with real inductors. Then try gyrators. Flynn wanted pure authenticity, down to the last component. That precludes the use of gyrators in their product. I'll also forgo the dual 741 (1458) opamp. It's what was available at the time. We have better shit now. W-taper pots will be an improvement.
Chuck D. Bones
Circuit Wizard
Here's the simulation results. LPF (treble boost) engaged, VOL at noon, BASS, MID & TREBLE at 7:00, noon and 5:00. The B,M & T pots should be 1K, not 10K. With 10K pots, all of the action takes place between 7:00 and 8:00, 4:00 and 5:00. Much more uniform change with rotation using 1K pots.
IMO, we'd be better off using a 10-band EQ with a clean boost. Like every other great guitarist, Rory's tone was in his fingers.
fig
Village Idiot
Then it's clear we must simulate his fingers.🤪
One more question regarding the W-taper; would it be a universal improvement, or limited to particular tone configurations?
Chuck D. Bones
Circuit Wizard
W-taper works well for the tone control circuits discussed in this article. They would not be desirable in the Baxandall, for instance. This is the tone sweep in the Hawk pedal. MID is shown, but it's the same for BASS & TREBLE. LPF off, VOL, BASS & TREBLE at noon.
With B10K
With W10K
With B1K
W10K gives the most even spread, but B1K is very close and much easier to obtain.
Chuck D. Bones
Circuit Wizard
None of them are even close to being enough inductance.
Not to worry, gyrators will work very well and will satisfy everyone except the hard-core cork soakers sniffers.
Chuck D. Bones
Circuit Wizard
After further thought and review, I have produced new Tone plots based on the Flynn Hawk manual. With only two exceptions, all of the recommended settings have BASS, MIDDLE & TREBLE set between 9:00 and 3:00. The freq response plots are very different at the more moderate settings. All stock component values, all controls at noon except the one being swept, LPF off.
TREBLE at 9:00, noon and 3:00:
MIDDLE at 9:00, noon and 3:00:
BASS at 9:00, noon and 3:00:
Bottom line: it's prefectly ok to leave the Tone controls as B10K.
Chuck D. Bones
Circuit Wizard
There is another pedal that does more-or-less the same thing the Hawk does: clean boost with 3-band boost/cut tone controls. It's the EQD Talons with CB-mod v2.3. The clip switch allows the clipping diodes to be disconnected. With VOLUME dimed, you can use the GAIN and VOICE controls to vary the overall gain from 0dB to 54dB. I set mine up with a charge pump to make an 18V rail. If C4 is reduced to 100nF, then the 1st stage is a treble boost, just like the Hawk.
Chuck D. Bones
Circuit Wizard
I ran a sim of a Hawk using gyrators in place of inductors. The freq response is very close to the inductor version. I scaled the impedances to allow the use of W20K pots. Here's the LTSpice model. It has not been breadboarded... yet. Treble sweep shown.
