I wouldn't know, you're the proNow that I took a better look, I wonder what C4 is doing there. A 100nF cap right across the output? That's odd. Can the op-amp drive that without oscillating? (Not that I haven't done much worse myself)
The second "op amp" is part of the power supply, not in the audio stream. It's a "voltage doubler"—I think in this case it's used so that there is a 27V differential between rails—far more swing than you'd get with 9V. And the op amp that is in the circuit is one that really appreciates more voltage. Besides having built this, I have the Holy Fire boost that this is an offshoot of—it originally came with a 48V wall wart to power it.I wouldn't know, you're the proPeople keep bringing this one up as a great transparent volume boost so I guess it works. I do have the board and parts here, just haven't gotten around to building it.
There's more stuff I don't really understand the purpose of. The second op amp seems pointless. I also don't understand R6 and R7. Are they for stability? Couldn't they have just designed it around a single op amp, deleted IC1.2 and R7 and be done with it?
The power supply I'm pretty clear on. It looks to be taken pretty much straight from the datasheet of the TI LT1054 (Figure 22. Dual-Output Voltage Doubler) with different diodes/capacitor values. It puts out +/- 18V minus some diode drops as far as I know. Pretty damn good and very useful for a clean boost!The second "op amp" is part of the power supply, not in the audio stream. It's a "voltage doubler"—I think in this case it's used so that there is a 27V differential between rails—far more swing than you'd get with 9V. And the op amp that is in the circuit is one that really appreciates more voltage. Besides having built this, I have the Holy Fire boost that this is an offshoot of—it originally came with a 48V wall wart to power it.
That’s the one I want to see. Know if there’s a schematic out there?The second "op amp" is part of the power supply, not in the audio stream. It's a "voltage doubler"—I think in this case it's used so that there is a 27V differential between rails—far more swing than you'd get with 9V. And the op amp that is in the circuit is one that really appreciates more voltage. Besides having built this, I have the Holy Fire boost that this is an offshoot of—it originally came with a 48V wall wart to power it.
Hah. I get that referenceR6 is the "clean blend" for more mojo![]()
