ErickPulido Active member Mar 20, 2020 #1 I have checked the schematics and the are just little differences, so if I use the values in the Isosceles (just grind part) the Triagulum would be good to go??
E eightbitinfinity New member Apr 10, 2022 #2 It would be amazing if PedalPCB would upload a doc schematic to wire the Isosceles Boost as a Grind
mdc Well-known member Apr 11, 2022 #3 Probably if you post in the modifications forum and provide schematics for everything, someone will happily help you figure out how to make it work.
