Bouge
Hi All,
I've built a few pedals from here, all successfull. So far I've always been able to troubleshoot faults in my builds quickly.
Build #5 seems to be beyond the ability of my usual truobleshooting equip/techniques.
This build is an Arachnid board, which worked fine during testing immediately after first assembly on my workbench, soon after the signal cut out leaving only the clean signal. when I max out the mix pot i get nothing, when I turn it back, the clean signal comes through.
I have traced the entire circuit for correct voltages using a multimeter at all the boards components and am confident the simpler components are doing their jobs. (I also have a functional Arachnid for reference, build #3) I have also swapped the opamp and eeprom chips between those builds and found them to work perfectly.
A quick google search recommends I build an Audio Probe and start poking around the fv-1 circuit, which i'll be trying this afternoon.
Any advice is greatly appreciated, thx.
~Bouge
~Bouge
