reynolds087
I just built the tyrian distortion, and it sounds amazing, but the problem is that it's ridiculously loud even with the volume set to almost zero. It sounds best with the volume around 12 o'clock, and the gain up reasonably high, but at that level, the clean bypassed tone is probably at least an order of magnitude or two quieter. Is this pedal only meant to be used as a standalone preamp? I am running it through the front of my amp because I don't have an effects loop, but it's completely unusable at the moment. I have to strain to hear the clean tone when the distortion effect is at correct volume level.
Attaching pictures of the build just in case I screwed something up, but I checked every component and I'm fairly confident it is assembled correctly.
