UberDrive (no signal with effect engaged) *now with extra updates!*
gutter0909
Hey all,
Second pedal not working right off the bat and second thread I've started. No shorts, everything seems to be wired up correctly compared to the directions. The power works, LED is good but no sound with effect off or on. No sound period. I get the buzz if I touch the tip soldering point for both the input and output.
I'm so lost. I'm also getting discouraged because I'm 1 for 3 so far for pedals that aren't kits and I've screwed up 2 enclosures with crap drilling.
Please help! Thanks in advance.
Okay, I'll give that a shot. The metal is continuous over the top so I thought it wouldn't matter which side they were soldered to but I will move those two and see what happens. I'll update later this evening. Thank you!
Do you have a multi meter? I would check what voltages you are getting at the 8 pins of the op amp. Put the negative lead on ground and tap the positive lead to each of the op amp's legs in succession and post here what your voltage readings are.
Ok those values all look correct. We've verified the op amp is secured in place correctly and operating correctly as well.
Silence when the circuit is engaged usually means the signal is shorted to ground somewhere.
How are the pins underneath your tone pot? On the backside of the switch PCB, are any of the leads touching each other?
