OTHER Unanswered template requests
Audandash
Okay folks if you have outstanding drill templates you are looking for I am going to try and start working through them. If you are the one who requested it I will DM you when I get to it. I will need you to get a few measurements for me so you will need to have the board in hand. No pictures please. If a build doc has numbers great. I will use it but I like to verify on the actual board. I need you to pull out a ruler and I prefer mm. If i post a template in the Tayda area I will also be able to give you the illustrator ai file for artwork if you like. Its part of my process. Please post request per the norm in the request area. I will likely let it sit for at least a week or two before I do this for you. Someone else may already have it and I want to give them time to respond. I am really good at this but like most diy use at your own risk. I am going to do this because I like it and the number crunching helps me manage my stress and anxiety.
One last thing. When I post the template you requested in the forum can you please update the request button at the top left to whatever the box is? 125b etc….. Only the original poster can do that (I think). This will help me work though them more efficiently.
What are the main measurements you need? I've got a backlog of Deadend FX PCBs that I need to box up and was starting down this path myself.
Give me a few priority boards you want done then I will look at the site and see what the build doc shows. I can use that to figure out what i would need.
