That’s missing pwr gnd reference for pcbs, won’t work as intented.Pretty sure this will work and is cleaner.
Still wondering if that's possible with the toggle though
I'm trying to work out this wiring.
You only need one ground on the PCB right? I only need to connect -(negative) OR GND not both?
Also is there any way to use a 3 way toggle instead of two toggles? I'd like:
POS1 Fuzz only
POS2 Both Fuzz and Boost
POS3 Boost only
with LED indicator
Pure gold, there!...
To consider:
-Keeping power - and pcb gnds separate until star point (and single lead to power jack -), probably doesn’t matter but one way to ease it is to think signal and power grounds as different streams leading to same river. ...
