UniCab
tdukes
This sounds awesome with my setup. I am using a Frog pedals tube preamp I made and then going into this and then into my usb connected recorder. I splurged on the love myswitches knobs.
This does have noise when the power is turned on and off. If you are in a quiet setting make sure to bypass before turning on or off.
Here is a picture of my tube preamp I have in front of this.
I´d love it had the balanced output
I agree. The baja cv30m1960a veroboard speaker simulator I was using had balanced out, but I used 16v caps at the output. Someone turned on phantom power. I don't know how long they lasted that way, but when the caps popped, they damaged the board. I was rebuilding, but this sounds so much better I think I will use it and then a DI box.
