Update Muffin Fuzz + Kliche Overdrive
gtfields13
Build Rating
5.00 star(s)
I want to update my post on my first two builds (PPCB Muffin Fuzz in Stomp '75 build and Kliche Overdrive).
After living with these for a week, I tried switching out the diodes on the Fuzz for germanium or LEDs in various combinations, but in the end I've decided I like the way the 1N4148 diodes sound - there was something grainy or rough with the other variations I tried. I did change the resistor on the output stage to increase the volume, because I found the output signal seemed limited. I dropped R22 from 4.7k to 3.3k. This might be a little too much change - I think that maybe a 3.9k would be the sweet spot here. I also find my 5mm LED a bit dim, and would probably change the RLED from 4,7k, too, if I built this again. At the end of the day, I find that the sweet spot for sounds is between 9 to 3 on for Volume and Tone, and the Sustain does something nice from min to max.
I think that this pedal works great in combination withthe Klon Centaur clone (and driven by a very 80's Fender Strat with Lace Gold pickups). I read that the Ram's Head Triangle was scooped in the mids, but that the Klon had a compensating mid-range boost. After playing around, I get it. The stock build works perfectly well (again, I would probably brighten the LED a touch) and the volume seems a bit high, but I am not looking to change that. I like the Klon at at the lower end of gain with the tone maybe 2-3 o'clock and the volume set so there isn't a noticable jump switching between the effect and bypass (maybe 9-10 o'clock for me).
it's definitely the combination that I like. With the Klon off, the fuzz makes for a nice rhythm guitar tone - nice heavy fuzz that fills in space in the mix without being dominant, but as soon as I switch in the Klon, the sound jumps right out. It makes a perfect way to go back and forth in the mix from lead to background without being to obvious. There is just a little more bite when both pedals are on.
If anyone has one or the other of these, I think you will like adding the other, and if you feel a need to play with the circuits a bit, I would definitely recommend tweaking the volumes.
Very cool combo. For a stand alone muff pedal, you can also change the capacitors to get a flat or even mid-boost. Not sure which version of the Muffin you built, but doubling C11 often does the trick.
Check out the site "tsc in the web", it graphs different amp and pedal tone stacks (including a big muff type) and you can modify the component values and see what happens.
I have tried this exact combination and have to agree! I sold my '73 Ram's Head build as I want to do either a Triangle or the '75 (Mascis) version. I head you on those read LEDs being a bit dim. I finally realized I should drop the CLR down to 2.2k or so for those.
