VHT Special 6 Ultra - lots of mods
maertz13
Howdy. I've got a VHT Special 6 Ultra that was purchased for the singular purpose of demoing pedals for videos. It needed a couple things to make it more flexible. Firstly a selectable bright cap on the "Ultra" channel. It's really dull under half. Added diode clipping per Rob Robinette's instructions.
The two places I could use a little help is the variable power control and installing a master volume. The power sag sounds awful at any setting. entirely useless. to bypass it would I just solder the wires from pin 3 and pin 2 of that control together so it is set at "max" or would it be best to bypass the entire section, mosfet, zener, and all? If im not mistaken, it would be jumping from node 75 to node 54. or will leaving it in-circuit but set to max essentially be the same?
"why not just leave it?" great question. I intend to use the 1M pot and it's ground connection for the master volume, outlined here https://robrobinette.com/Special6UltraMod.htm#Master_Volume
my hope is that I will now have a much more flexible crunch sound and not get evicted for turning the channel volume up to 1.
My VHT amp (D-Fifty) is very end user mod friendly. I'm assuming the Special 6 Ultra is the same? There's some good tones in that little thing!
yes, it was intentionally built on eyelet board to make it a platform for mods. everything has been easy to get to, just when it comes to power related things I'd love a second opinion 😅
Well I sacked up and put it all back together. Master volume works wonderfully. It’s probably the most crude MV, but it works and it’s not obliterating the tone.
Jumpered over the variable power section. Nothing caught on fire, so I’d say that worked fine.
Bright switch ks phenomenal. The “ultra” channel is just half a tube being driven and pushed into the next. Trying to use it for tiny bits of breakup always nuked the high end. Now I have a 3 way switch.
The diode clipping isn’t behaving 100%. One of the settings works, obviously “off” works, but the other setting is either so subtle I can’t hear it or not actually working. That’s a later issue.
First amp mods. Didn’t blow myself up. I’d like to thank Rob and Lyle and Brad for making this sound easy enough to get my stupid ass to try it
I “fixed” the diode clipping to the point where both sides worked, but wasn’t satisfied with the sound. So I moved it to where Friedman/jose put hard clipping. And that sounded just awful.
So I’m officially at a loss about what to do with that. At the last stage of the preamp, where rob said to put it, the clipping was SO bright and scooped. I thought a 470pf cap would smooth it out, but no. Apparently it needs a MUCH larger cap there. Or to find a more appropriate place to put hard clipping.
I’m open to ideas
