Synchrony Pedalworks
1. When I place a boost or OD in front of the VIIB, I get a whine similar to the LFO. Any suggestions on where to look first for the problem?
Otherwise, the pedal functions well and without the whine. The problem is only when gain is added.
2. I want to use my switcher with the pedal, but when power is first applied, the pedal is always off. Is there a way to get the relay to start as on?
If this problem is solved, then #1 is not a problem. The switcher can fix my order issue (VIIB before gain).
Thanks!
Thanks!
