MacGuffin_
Working on my byrdhouse again: when the vol is turned up (on amp) I get a intense buzzing, when ATK is up I get warbling, and overall a country radio station keeps seeping through my sound.
I have checked every grounding point and they all look good, but when I body-ground a few points it clears up. Any tips for getting it grounded? I've tried powering through different plugs (it was on the same plug as the amp on a power conditioner first) with no luck. It is also warbling when ATK is high (above ~80%), which is a bit annoying. Finally I can't get rid of a radio station on my pedal that is getting through some ground loop.
Things I found:
- grounding with my body cleared up a lot of noise that is normally there
- cant get the warble to go away, but it only appears with high ATK. Trim knob didn't do much to stop it
- touching the input wire makes a earsplitting crackle
- idk what I am doing
Things I found:
